1 - 11 of 11 Posts
Just picked up a 2006 smart with a problem in which shifter will not go into park... key is on in key 2 position foot on brake.. shifter moves fine in all gears and selection just will not go past reverse... local mb smart car parts shift stocks a shifter assembly .. the person who I bought the car from said his mechanic said to replace shifter.. anyone else have this problem ??
Yeah that works just fine except the state of Virginia will not pass it for a state inspection.. I have a new shifter coming Tuesday will see what that does
I'm still not understanding here. So the shift pattern in a 450 is "+1 -1 N R". There is no Park. To park a 450, you shift it into Reverse then shut it down. This locks the transmission into place.
If the unit the dealership is sending you has a "Park", it's a unit for a 451 and won't work in your 450.
Reactions: jwight
Discussion Starter · #7 ·
New Shifter Installed
Got my new shifter in from Mercedes... installed into car car finally goes into park per gear shift indicator dash says other it says “n” on digital display should it say this or “p” 2008 smart passion... once I start car run thru gear and try to go back to park per the indicator on shifter says park the dash says “1” and with some fiddling it goes back to “n” did I mess something up?
OTD3 lifetime Member
I know this is an old thread, but one of my 2009s has just developed the problem Eaweld described above. No "P" on the indicator with the shifter in "P". Either shows "1" or "N". The parking pawl engages normally, and the car starts in "N" and seems to drive normally. What did you do to get the indication corrected?
1 - 11 of 11 Posts
