1 - 20 of 20 Posts
I think that is what it is called....it says it is due for maintenance in 10 days but the only thing it is due for is an oil change at 30,000 miles and I am only at 21,000....any other maintenance required before 30,000 that you all know of?????????
And if I need an oil change can any place do it or do I have to deal with Toyota again or a Mercedes dealership, as that is where I bought the car....some of you know that story LOL.
I change my own oil, buy it at Costco and the filter from Rock Auto.
The reset is done by holding in a button (I don't remember which one right off) for some fair amount of time.
I'm sure others will chime in with more data.
S u b R o s a
I would be surprised if any "quick" oil change shop has the proper filter in stock....maybe buy one and bring it with you. Resetting the maintenance mileage is done through the menu in the instrument cluster. Download the owners manual here: download vehicle manuals | smart USA
It is a rather easy do it yourself process....(although the 451 was much easier!), and doing it yourself, you can make sure it's done correctly. I've done mine twice in the last 6 months myself...it saves quite a lot of $$ from going to a dealer. I found this video very helpful:
I bought the BECK/ARNLEY Filter as I believe that is what is OEM.
2017 SMART FORTWO 898cc L3 Turbocharged Oil Filter | RockAuto
Tire Wheel Vehicle Car Hood
You hold the button on your left-hand side while the car is just turned on and you’re not started you have to hold it for it seems like 45 seconds as soon as the all white striped blanket and keep holding onto it and then you’ll see a recent total and then you have to answer yes or no
The maintenance reminder can be reset much more easily on the 453 than on the 451. The procedure should be described in your manual - if you have one. Go to the next to last screen on your dash where you see the mileage reminder. The center button has to be held down for several seconds. Don’t remember if the motor must be running.
Discussion Starter · #6 ·
Can not change my on oil...where I live it is not permitted and also I just do not have the tools nor the stamina.....Toyota will probably not have the right filter either which means I will have to drive over 50miles to the Mercedes dealership and pay whatever they will charge for a lousy oil change...which right now is not even due till 30,000miles...and at 21,000 miles and me only driving about 1,000 miles a year it will take me almost 9 years to get to that...LOLLLLLLLLLL
Here is the 'right' wrench for that 8mm square drive oil plug:
Tool Bicycle part Wood Bumper Composite material
BTW, the '16 453 had several part numbers for the oil filter, make sure what you order matches what you have. Mine looks like a gas mask cartridge, same as shown in the video.
SR
Discussion Starter · #8 ·
SR
oil change not permitted where I live....probably have to pay a fortune to get it done at Mercedes dealership.....
You can buy a filter from Amazon and take your car to most any place that does oil changes. Just need to make certain they have the square end wrench to remove the drain plug and the proper sized socket to remove oil filter cover. Also, you could buy each tool and allow the place you select to change your oil to use them. It’s not a rocket science job.
Oil should be changed at least annually..... Like I said, buy a filter from the link I sent you and take it with you.
In the records that came with my Smart, the charge for an oil change was $180 from a Mercedes dealer
67086
Discussion Starter · #14 ·
In the records that came with my Smart, the charge for an oil change was $180 from a Mercedes dealer View attachment 67086 .....
$180 for an oil change.....hope they take me to dinner as well. I looked up on car fax and it says an oil change for my car in my area should be about $45...think they better check that again.
Discussion Starter · #15 ·
Just looked at my car fax here was the last oil change....
Last Oil Change
07/20/2020 | 19,572 Miles
by Toyota of Warren
  • Vehicle serviced
  • Pre-delivery inspection completed
  • Fluids checked
  • Oil and filter changed
I right now have 21,811 miles....why have oil change with only driving 2,239 miles??????
Service reset..On the steering wheel, select the menu's, go down to service reminder/reset display, hold the OK button, the display flashes, keep holding the button, and wait till it stops flashing and is set back at 12,000 miles. This can take what feels like two minutes, but just keep holding button. (This reset is useful as the service reminder can easily go wrong and give you a reminder months before it is necessary for a service. It does on my 453. I have had to reset it many times, its just weird electronic glitches you get sometimes on the 453)
Discussion Starter · #17 ·
Service reset..On the steering wheel, select the menu's, go down to service reminder/reset display, hold the button, the display flashes, keep holding the button, and wait till it stops flashing and is set back at 12,000 miles. This can take what feels like two minutes, but just keep holding button. (This reset is useful as the service reminder can easily go wrong and give you a reminder months before it is necessary for a service. It does on my 453. I have had to reset it many times, its just weird electronic glitches you get sometimes on the 453)
Thank you so much...everything else on my car was inspected and serviced back a few months ago when other repairs were needed at Mercedes and I am sure an oil change was not needed.....will reset....thanks.
2017 453 Passion ED/EQ
Yeah, mine just popped up with a count down service reminder, but reset to 10,000 miles! Weird. Oh well..🤷‍♂️
The one thing i cannot stand with the service reminder on the 453, is the 30 day countdown to the service.
I see 30 days to service, then 29 days to service, then 28 days to service,
I feel it is a countdown for a bomb to explode in the car :D
So when the service reminder does comes up, I just reset it right away LOL.
1 - 20 of 20 Posts
