21 - 23 of 23 Posts
jwight: I'll check that out, thanks!
chieftmc: I had pulled the rear panel apart when removing some weird latch thing the PO had installed. The switch was in place and when I reassembled everything, I could stick a bent paper clip in there and make the thing work, but the thing in the handle that presses on that switch is not there. An entire assembly would work, but if I can just buy that piece that fits into that recessed area, I'd be all set. Guess I can try to fabricate one... :D
When she comes out push the unlock button on the center dash and then she can push the button located under the lip over top of the license plates and she is in. No strings or drills or push rods required. Just like the fuel cover door the doors have to be unlocked to get in.
Yes, this is the only way I know how to open the back hatch with the key in the ignition.
Stevechilton
same problem as others cant open tail gate 452 /2009 cabrio tried all things apart from pull cord not sure i understand how to do this any iea would be appriciated
21 - 23 of 23 Posts
