The 2013 Passion Coupe I just bought has a cargo cover installed but it doesn't work. Not sure if it's in there wrong or what? When I pull it up, it comes up half way then stops. How can I either take it out and start over or has anyone else had this issue? Thanks!! :confused:
The far left side of the cargo cover is a spring loaded handle. Try pulling it to its right and then you will find out how to remove and reinstall it. Then you'll get it all figured out.
Also you may find that in whatever position it may rattle. One solution is to take it out until you anticipate needing it. (Christmas shopping, any kind of anticipated shopping). It rattles worse the colder it is. Don't get me wrong-I love mine, but just so you know that strange sound may be the cover.
Sometimes lubing the ends will silence things. Silglyde is great for that.
A low pitch squeak that I thought was the suspension stopped abruptly when I used a rubber protectant on the passenger door seal.
