1 - 1 of 1 Posts
I removed the top of the center console to access the area below it to install an USB data port. I haven't put the USB port in yet, bad weather. You pull up on the rear of the panel top to release the clips, then work your way forwards on both sides towards the radio. The front slides back to disengage the tabs. Before you lift it too high, reach in and disconnect the white 6 wire connection for the shift pattern LED's just in front of the shifter. That will give you enough room to pull the top up and over the shifter (dual clutch model.) I had to put the shifter in drive and put the button on it to get the top over it. Disconnect the sport/economy switch wire connector underneath the panel and it's off.
1 - 1 of 1 Posts
