It is normally called a 'flush', however you will want a drain and fill done using a negative pressure method where the old fluid is pulled out under pressure and new fluid is pulled in to replace the old fluid. Had it done on my smart at an independent service shop - cost around $100 for a standard coolant exchange - not the Waterless.
Sent from Android using Tapatalk
