Plan to get them at rockauto. Anything weird or curveball about this job?
It's not terribly difficult. Removing the struts and getting the "hat" off the old strut were the hardest parts for me. If you've done a set of struts before, it's not much different.Plan to get them at rockauto. Anything weird or curveball about this job?
You can try Autobahn: Drivetrain & Suspension — Autobahn Used SMART 451 Parts or MB Online Parts: Suspension Components for 2010 Smart Fortwo | MB Online PartsRock auto didnt have springs. Anyone have a source? I saw it on here long ago but cant find it now.
On the 451 it helps to spread the clamp of the knuckle open where the strut goes into it, but the real answer is to push it out from the bottom. If you have a hydraulic press, you're golden and it will be quite easy.. If a press is out of the question, you can use a hammer. Try not to beat on the shock itself, use a block of dense hardwood or similar because if you bash the metal on the strut with the hammer, you'll mushroom it and make it harder to remove. Patience is key with suspension because just about everything is rusty.I've dropped the struts to change the springs on my 2015 Pure, but I've yet to pull a strut out of the hub assembly. Anyone have any comments on that procedure?
The thread I linked above has part numbers. I ordered all of my parts from eBay, RockAuto, and mbonlineparts.comRock auto didnt have springs. Anyone have a source? I saw it on here long ago but cant find it now.
A You Tube video was great. I got the micro flex ratchet that made removing the top nut uneventful.Plan to get them at rockauto. Anything weird or curveball about this job?
Downtown which utube vid did you watch? The guy with the yellow car?
Also is it cheaper and or easier or smarter to buy the whole strut/spring together? I already have the struts and mounts.
Yes, I remember the cat. The ratchet and socket worked well. I did not need to make a special socket. A regular socket and PB Blaster worked for me.Downtown which utube vid did you watch? The guy with the yellow car?
No bump stops. Just the donuts. Definitely replace. Cheap insurance. Consider sway bar links and bushings.Also I ordered the mounting (donut?) for the struts. Are there any other parts I'd want to replace? Are there bump stops that are probably gone?
Depends on the springs, I would stick with known and trusted brands (Sachs, Eibach, etc). They cost a little more, but typically only a little and I would avoid any used ones.Downtown been reading the thread you linked to. I found oem springs on ebay for $126 for the pair. Is the consensus that they are inferior or that a closely priced aftermarket is better? I want to stay with stock height since the roads around here are like a missile testing site.
There's a bearing that often comes with the donut, make sure that's included.Also I ordered the mounting (donut?) for the struts. Are there any other parts I'd want to replace? Are there bump stops that are probably gone?
