Is there like a portable charger to charge Smart Fortwo electric while away from home?
Welcome to SCoA.Yes, but is there a portable charger that doesn’t need to be plugged in? NO. Like can you charge the partabke (portable?) charger and take it in case of an emergency? NO.
You have an electric vehicle and ask this question??Yes, but is there a portable charger that doesn’t need to be plugged in? Like can you charge the partabke charger and take it in case of an emergency?
It's a question that lacks a good engineering answer (and is therefore an impractical idea).
I don't think it's a ridiculous question on the face of it, though.
Has anyone tried carrying a portable generator when on the road. I know you would have to spend a few hours at a rest stop or friends house to use it but I think a 2KW generator would be big enough?
That car is already out there. The Chevy Volt and Cadillac ELRHas anyone tried carrying a portable generator when on the road. I know you would have to spend a few hours at a rest stop or friends house to use it but I think a 2KW generator would be big enough?
2kW at 120V is 16.7 Amps. The Smart charger on max charge is 12A IIRC, so if the 2kW generator can legitimately put out 2kW on a sustained basis, you should be fine. (You could also limit the car to an even slower charge rate if you needed to, either to get the generator to speed up to carry the load and then switch to the higher amp setting on the charger, or just to put a few miles of charge in it to get to someplace.)Has anyone tried carrying a portable generator when on the road. I know you would have to spend a few hours at a rest stop or friends house to use it but I think a 2KW generator would be big enough?
I totally agree with you. My first and last GM products were in the early 80's.Yes the Chevy Volt is the perfect car until the high-range EVs go down in price and until the EV charging infrastructure improves - which, if anything, is in retreat right now. Here in Pittsburgh, EV-sightings have declined considerably since a peak in 2014.
Shame that GM never made any effort at all to market the Volt, and they will be discontinuing it after this year. Every owner - people who would have never bought any other crappy GM product - loves it.
GM is doing nothing to promote the Bolt either, and its days are probably numbered too. EV progress resolutely marches in reverse in the USA right now, and many parts of Canada - especially Ontario.
