1 - 20 of 282 Posts
Anybody have problems with the clearcoat peeling on their smart? I've got a 2009 red smart, solid color, and a 2008 red smart, painted, and the '09's clearcoat is peeling. I use the same soap & wax on each but only the '09 is peeling. The '09 has the red plastic, the '08 is red painted over a black plastic panel. Could the fact that the clearcoat was applied to the plastic, not paint be the cause?
Quick search shows you're right :eek:.
You're not the first with this problem, I wonder what the build dates of all the reported cars are...
Could it be possible that the mixing of paint or prep of the panels was done poorly?
We always hear comments about American car quality being so so, perhaps Hambach has its own issues too. There is no excuse however.
Clear coat peeling, '09 Rally Red:
There is a member of the Inland Empire smarties that has an 09 rally red Passion. The rear center panel has the clear coat lifting. My wife has an 09 rally red and there is no evidence of the clear coat peeling off. As mentioned in some of the other posts, this is probably a batch problem where the clear coat wasn't applied correctly. Try calling smartUSA & ask them to open a case or look into the matter. If they get enough complaints, they might decide to replace the damaged panels, if the clear coat peeling was caused by a manufacturing defect.
I'd agree with the batch issue theory.
Perhaps we should gather build dates to see if they're close to each other?
There is a member of the Inland Empire smarties that has an 09 rally red. The rear center panel has the clear coat lifting. My wife has an 09 rally red and there is no evidence of the clear coat peeling off. As mentioned in some of the other posts, this is probably a batch problem where the clear coat wasn't applied correctly. Try called smartUSA & ask them to open a case of look into the matter. If they get enough complaints, they might look into the matter and replace the damaged panels.
Then you woke up, right ? :p
We just noticed on our 09 red passion the clear coat is coming off badly on the rear panel and on spots on the hood and doors... Worse when it has been washed...how do you find the build information? Love our smart and my husband has become the smart "salesman" people have followed him to work asking about the car then showing days later with one.... Don't really want people seeing this as its a turn off.
1 - 20 of 282 Posts
