Is this a clutch actuator adjustment or a clutch adjustment? The only reason I ask is because a conventional clutch is usually self-adjusting.
A conventional (mechanical linkage system) is not self adjusting. As the disk wears the fingers move out and the linkage needs to be adjusted,Is this a clutch actuator adjustment or a clutch adjustment? The only reason I ask is because a conventional clutch is usually self-adjusting.
Yeah I'm clear on that front - how about anybody else? Every 30K? Wait until shifting gets sketchy?
It took almost 98K before mine was noticable enough to do this little tutorial. I also do a lot of highway driving, very little in town driving. If you do all stop and go, you may need to do this sooner than I did. Personally, I would say every 60K would be plenty soon enough. I plan on pulling my actuator yearly to clean and re-lube.
So you did the cleaning/ lubrication, and the adjustment (first post in this thread) ?
Make sure you document it when you change out that clutchIt took almost 98K before mine was noticable enough to do this little tutorial. I also do a lot of highway driving, very little in town driving. If you do all stop and go, you may need to do this sooner than I did. Personally, I would say every 60K would be plenty soon enough. I plan on pulling my actuator yearly to clean and re-lube.
As I've said before, I'm a do-it-yourself kind of guy. I've worked on cars my whole life. Preventative maintenance is the cheapest insurance you can get for a car.
Hope this helps.![]()
Figured I'd try it now even though i'm at 45k. Notched it out by 1 marking and took it for a spin. Fantastic rolling 2nd gear accel now. no more long drag before it catches. much stronger bite i guess you could say. Thinking i'll probably try a corner into 1st gear and see how that bites up too.Yeah I'm clear on that front - how about anybody else? Every 30K? Wait until shifting gets sketchy?
Actually, I took the actuator apart and cleaned and lubed it last September, shortly before Outsmarting the Dragon. I'll do that again this fall, and see how the Lithium grease is holding up.
Correct me if im wrong but i was under the impression that the clutch on the 451 was only used for driving off from a standstill or when you were stopped. With each gear change (first through fifth) the gear speeds are matched up and then changed with no need for the clutch (the 'computers' in the Smart take over the throttle to control this and do the shifting). Short of like how you would shift a conventional 5 speed without using the clutch, ei matching the next gear. And the clutch would obviously only be engaged when coming to a stop.
Great write up by the way, but now im as confused as ever. I understand the need to adjust the clutch but it has been mentioned several times that the clutch was slipping with each gear change, and that adjusting it helped. If i am correct then the clutch would not be used with each gear change and just for initial drive-off and coming to a stop.
Please educate me......
