Hey Gang,
I’m going to be doing the clutch adjustment on my Mom’s 2006 smart car.
After reading lots of threads on this, I want to be clear on a few things.
1) Make sure the car is in neutral before/while doing this.
2) Disconnect the negative battery cable before starting.
3) Mark a line for a point of reference before removing clutch actuator.
4) Lots of penetrate on bolts, possible heat for removal.
5) Actuator “should” be moved away from bell housing for adjustment, but could be moved other way as well… won’t know until the car is driven.
6) A little dab of grease on tip of rod that goes toward the clutch side.
7) Install a little grease on bottom of actuator to help it slide for future adjustment.
8) Don’t over tighten bolts ( 12lbs force )
Anything else I should be aware of?
