Once you have the motor out, you can see it is sealed to the case with a rubber O-ring:
The case of the motor is held together by two tabs bent over the mounting flange. See following pictures:
Once you bend out the tabs and separate the motor, this is what you see:
It's just a simple DC motor. I have not had time to pin out the connector, but I will post that once I have time.
