I want to know if manually adjusting the clutch actuator is the same as using MB star scanner? when it has to be done, when replacing the clutch disk?
What about the " bite and release point adjustment", is just a different term for the same clutch actuator adjustment mentioned above?
So when adjusting electronically, does the computer calibrates the distance between fully engaged and disengaged of the clutch fork?will this distance remain fixed until the clutch disk wear out and then adjust it again?
The electronic adjustment should set engagement and release points for the clutch. I do not know if the 451 actuator mechanically adjusts for wear. I think that the 450 did.
