1 - 20 of 36 Posts
Many of you here now have battery test units in your possession. Yinzer and I thought it would be a good idea to have a thread where you could compare your battery test results to others, so we developed a short report form to share data. We think that the Ah numbers are most important, so we shortened our form to just report that. The Ah numbers are found near the end of the battery test report.
Please copy Post #2 to report your results. That way the reports will be pretty standard for comparison sake. Note the "period" at the very beginning of my two posts below. It seems as though there must be at least one character outside of the quoted message. Of course if you sign your post, that will take care of that too. Also I just made my notes in red to make it easier to read. We're happy to get your results anyway we can.
When doing your test, this info was sent to me from the All-Data subscription:
Battery - Maintenance or Status Check of High Voltage Battery
Date: May 6, 2014
Order No.: SM-B-54.10/09
Group: 54
SUBJECT: MY-All, Model 451.390/391/490/491
Preparation for Performing Maintenance Service or Status Check of High-Voltage Battery
Here is some text about prepping for the test:
"Drive vehicle (discharge) to < 40 % SOC (see left-hand round "SOC" dial on instrument panel).
^ Leave vehicle parked for approximately 2 hours (no driving, no charging).
^ After this idle period of approximately 2 hours, connect the charging cable, and fully charge the vehicle to 100 % SOC.
^ The vehicle can then be operated normally again.”
2014 EV Coupe 14,500 miles
2014 EV Cabriolet 4,500 miles
Discussion Starter #2
A. Date of test:
B. Battery production date:
C. Initial in service date:
D. Typical usage:
E. Location of car:
F. At what % do you typically recharge:
G. Current miles/kilometers (specify which):
H. Battery test results in Ah:
CAP mean:
CAP min:
CAP max:
Discussion Starter #3 (Edited)
A. Date of test: 6/21/2017
B. Battery production date: 11/8/2013
C. Initial in service date: 8/5/2015
D. Typical usage: 30 to 55 mph 10 to 20 mile trips
E. Location of car: Coastal NC
F. At what % do you typically recharge: 50% or less, rarely goes below 20%
G. Current miles/kilometers (specify which): 11,505 miles/18,516 km
CAP mean: 50.5 Ah
CAP min: 49.8 Ah
CAP max: 51.3 Ah
2014 EV Coupe 14,400 miles (above)
Discussion Starter #4 (Edited)
B. Battery production date: 3/6/2014
C. Initial in service date: 5/30/2017
G. Current miles/kilometers (specify which): 309 miles/498 km
CAP mean: 52.5 Ah
CAP min: 51.9 Ah
CAP max: 53.1 Ah
2014 EV Cabriolet 4,500 miles (above)
A. Date of test: 2018/4/16
B. Battery production date: 2014/9/10
C. Initial in service date: 2014/9/10
D. Typical usage: 35-65 mph 20-40 miles trips
E. Location of car: Central OH
F. At what % do you typically recharge: 40-80%
G. Current miles/kilometers (specify which): 13100 miles
CAP mean: 50.4 Ah
CAP min: 51.1 Ah
CAP max:51.9 Ah
I've had the car about 700 miles and 3 weeks at these numbers in ohio
It doesn't seem like this data is from when I took the test (4/13), but rather the current state of the batteries (Last measurement says 0 days). I had to drive 23 miles and had 60% SOC when this test was run. Thanks again to Jim and Len (and Kris!) for lending this unit for the reading.
Bobby
I did not follow the test procedure, I'll give that a try tonight.
A. Date of test: 2018 / 4 / 30
B. Battery production date: 2013/2/4
C. Initial in service date: 2013/2/5
D. Typical usage: Everything
E. Location of car: Raleigh, NC
F. At what % do you typically recharge: Anywhere from 1% to 70%
G. Current miles/kilometers (specify which): 35,868
CAP mean: 48.9
CAP min: 47.9
CAP max: 49.8
Drove car to 24% SOC, let it sit 1h45m, charged to 100% - readings from the bottom section of Min/Mean/Max
CAP mean: 50.1
CAP min: 49.2
CAP max: 50.8
Tested the 2014... it was at a low SOC, sat half the day, then fully charged between lunch and when John got off work.
B. Battery production date: 2014/1/27
C. Initial in service date: 2014/1/27
D. Typical usage: 10-20mi/day
F. At what % do you typically recharge: Anywhere from 10% to 40%
G. Current miles/kilometers (specify which): 20k
CAP mean: 50.9
CAP min: 49.8
CAP max: 51.5
Discussion Starter #9 (Edited)
This is the same car as reported in Post #3 above just a year later.
A. Date of test: 6/5/2018
G. Current miles/kilometers (specify which): 15,319 miles/24,655 km
CAP mean: 50.6 Ah
CAP min: 50.3 Ah
CAP max: 51.1 Ah
2014 EV Coupe 15,000 miles (above)
2014 EV Cabriolet 5,000 miles
Discussion Starter #10 (Edited)
This is the same car as reported in Post #4 above just a year later.
A. Date of test: 6/4/2018
G. Current miles/kilometers (specify which): 5,355 miles/8,619 km
CAP mean: 52.6 Ah
CAP min: 52.0 Ah
CAP max: 53.3 Ah
2014 EV Cabriolet 5,000 miles (above)
A. Date of test:June, 2018
B. Battery production date:2017
C. Initial in service date:7/2017
D. Typical usage:commute or to train
E. Location of car:home NYC area
F. At what % do you typically recharge:50 60%
G. Current miles/kilometers (specify which):42000 miles
CAP mean:52.3
CAP min:51.2
CAP max:52.4
battery was replaced 2017 July, car is 2013 ED coupe
A. Date of test: 6/6/2018
B. Battery production date:2013/11/26
C. Initial in service date:2014
D. Typical usage: 20 mile daily commute
E. Location of car: Chicagoland Area/Near the Lake
F. At what % do you typically recharge:40%
G. Current miles/kilometers (specify which):12300 miles
Last measurement : 5 day(s)
Measurement estimation: 0.808
Actual estimation : 0.679
CAP mean: 17834 As/10, 49.5 Ah
CAP min : 18037 As/10, 50.1 Ah
CAP max : 18382 As/10, 51.1 Ah
CAP mean: 17850 As/10, 49.6 Ah
CAP min : 17659 As/10, 49.1 Ah, # 50
CAP max : 18099 As/10, 50.3 Ah, # 69
In the last week, we've driven our ED more than typical, and much of that on the freeway. Earlier today, my wife drove the ED running a bunch of in-city errands and got in excess of 1 mile per 1% SOC - she drove over 30 miles with the SOC still showing about 73-74% full. I then ran it down further with a longer freeway run and seemed to get a bit more than normal range.
Here's a battery test from July 21st:
Individual Cell Statistics:
CV mean : 4182 mV, dV= 27 mV, s= 2.71 mV
CV min : 4157 mV, # 10
CV max : 4184 mV, # 37
CAP mean: 18267 As/10, 50.7 Ah
CAP min : 18024 As/10, 50.1 Ah, # 24
CAP max : 18380 As/10, 51.1 Ah, # 27
Voltage Distribution (dV= 27 mV):
4157 02 > [4182; 4182; 4183] < 00 4184
min [p25; median; p75] max
Reading data....OK
Status OBL Charger-Unit:
User selected : 16 A
Cable maximum : 204 A
AC L1: 126.0 V, 0.6 A
DC HV: 387.9 V, 0.0 A
DC LV: 14.1 V
Temperatures Charger-Unit /degC:
Reported : 27
Cooling plate : 27
Inlet socket : NA
Reading data.OK
Status Cooling- and Subsystems:
Temperature : 24.4 degC
Cooling fan : 0.0 %
Cooling pump : 38.8 %, 23 degC
: 13.9 V, 0.4 A
OTR:
Cooling fan : 9 h
Cooling pump : 2387 h
Battery heater: 0 h, OFF
Vaccum pump : 13.165 h
Pressure 1, 2 : -721 mbar, -727 mbar
Battery VIN: WMEEJ9AAXFK834189
Time [hh:mm]: 11:24, ODO : 16029 km
SOC : 100.0 %, realSOC: 99.2 %
HV : 389.9 V, -0.75 A, -0.29 kW
LV : 13.4 V
And here it is from just now:
CV mean : 3770 mV, dV= 15 mV, s= 1.69 mV
CV min : 3757 mV, # 10
CV max : 3772 mV, # 45
CAP mean: 18883 As/10, 52.5 Ah
CAP min : 18719 As/10, 52.0 Ah, # 24
CAP max : 19096 As/10, 53.0 Ah, # 10
Voltage Distribution (dV= 15 mV):
3757 00 > [3769; 3770; 3771] < 00 3772
Reading data....OK
AC L1: 112.1 V, 11.8 A
DC HV: 350.4 V, 3.7 A
DC LV: 14.3 V
Reported : 49
Cooling plate : 44
Inlet socket : NA
Reading data.OK
Temperature : 35.4 degC
Cooling fan : 0.0 %
Cooling pump : 39.2 %, 35 degC
: 14.0 V, 0.2 A
OTR:
Cooling fan : 11 h
Cooling pump : 2651 h
Vaccum pump : 14.632 h
Pressure 1, 2 : -685 mbar, -690 mbar
Time [hh:mm]: 16:30, ODO : 18027 km
SOC : 59.0 %, realSOC: 56.7 %
HV : 352.8 V, 2.72 A, 0.96 kW
LV : 14.1 V
I think right now, temperatures are about optimal for charging/discharging, and it again shows that the battery statistics can be improved by consistent usage at higher discharge rates to a deeper depth of discharge. We're now about to leave on a four week long vacation during which the ED will sit. We're intending on leaving it at about 65% charged and will see what happens after we get back.
2014 ED Battery test, 7k miles
A. Date of test: 10/6/2018
B. Battery production date: 03/10/2014
C. Initial in service date: 07/21/2014
D. Typical usage: 30 to 55 mph 5 to 10 mile trips
E. Location of car: East Coast - VT
F. At what % do you typically recharge: 80% or less, rarely goes below 50%
G. Current miles/kilometers (specify which):7150 miles / 11525 km
CAP mean: 51.6 Ah
CAP min: 50.6 Ah
CAP max: 51.9 Ah
I did NOT make sure that the car had been discharged below 40% in the prior 3 weeks, however, so it may not be a valid test. I'll test again in about a month.
Sean
2014 EV Coupe 7120 miles (above)
FULL RESULT:
........Reading data....................OK
Battery VIN: WMEEJ9AA3EK792026
Time [hh:mm]: 12:40, ODO : 11525 km
Battery Status : OK
Battery Production [Y/M/D]: 2014/3/10
Battery-FAT date [Y/M/D]: 2014/3/10
Rev.[Y/WK/PL] HW:2014/7/0, SW:2014/18/0
SOC : 97.0 %, realSOC: 93.1 %
HV : 381.9 V, 0.00 A, 0.00 kW
LV : 12.1 V
CV mean : 4105 mV, dV = 25 mV
CV min : 4083 mV
CV max : 4108 mV
OCVtimer: 5529 s
Last measurement : 7 day(s)
Measurement estimation: 0.743
Actual estimation : 0.599
CAP mean: 18583 As/10, 51.6 Ah
CAP min : 18212 As/10, 50.6 Ah
CAP max : 18692 As/10, 51.9 Ah
HV contactor state OFF, for: 69119 s
Cycles left : 296793
of max. cycles: 300000
DC isolation : 8651 kOhm, OK
Temperatures Battery-Unit /degC:
module 1: 14.4, 13.8, 14.1
module 2: 13.7, 13.6, 13.8
module 3: 13.8, 13.4, 13.5
mean : 13.8, min : 13.4, max : 14.4
coolant : 13.8
# ;mV ;As/10
01;4106;18354
02;4106;18309
03;4107;18309
04;4106;18309
05;4106;18220
06;4106;18175
07;4104;18087
08;4106;18175
09;4106;18175
10;4106;18220
11;4105;18309
12;4106;18175
13;4106;18264
14;4106;18264
15;4082;18000
16;4107;18354
17;4106;18131
18;4107;18131
19;4108;18175
20;4106;18131
21;4107;18220
22;4107;18354
23;4107;18220
24;4108;18309
25;4106;18309
26;4106;18220
27;4107;18175
28;4107;18220
29;4105;18264
30;4106;18354
31;4107;18264
32;4105;18354
33;4104;18309
34;4105;18309
35;4106;18220
36;4106;18309
37;4106;18309
38;4107;18309
39;4106;18264
40;4105;18264
41;4104;18264
42;4105;18354
43;4104;18220
44;4105;18309
45;4104;18220
46;4106;18309
47;4105;18175
48;4105;18354
49;4104;18264
50;4105;18400
51;4106;18220
52;4104;18309
53;4105;18354
54;4104;18354
55;4106;18220
56;4105;18309
57;4104;18220
58;4106;18309
59;4106;18175
60;4105;18220
61;4105;18175
62;4105;18220
63;4104;18309
64;4107;18309
65;4104;18309
66;4106;18309
67;4105;18220
68;4106;18309
69;4105;18354
70;4107;18400
71;4104;18220
72;4106;18309
73;4105;18264
74;4108;18354
75;4105;18220
76;4107;18220
77;4105;18264
78;4107;18264
79;4106;18220
80;4108;18220
81;4105;18175
82;4108;18175
83;4106;18220
84;4107;18400
85;4104;18264
86;4107;18264
87;4104;18264
88;4106;18309
89;4105;18309
90;4105;18264
91;4105;18220
92;4105;18309
93;4105;18175
CV mean : 4105 mV, dV= 26 mV, s= 2.67 mV
CV min : 4082 mV, # 15
CV max : 4108 mV, # 19
CAP mean: 18260 As/10, 50.7 Ah
CAP min : 18000 As/10, 50.0 Ah, # 15
CAP max : 18400 As/10, 51.1 Ah, # 50
Voltage Distribution (dV= 26 mV):
4082 00 > [4105; 4106; 4106] < 04 4108
Reading data....OK
User selected : 32 A
AC L1: 0.0 V, 0.0 A
DC HV: 0.0 V, 0.0 A
DC LV: 12.3 V
Reported : NA
Cooling plate : NA
Inlet socket : NA
Reading data.OK
Temperature : 13.6 degC
Cooling fan : 0.0 %
Cooling pump : 0.0 %, 13 degC
: 12.0 V, 0.0 A
OTR:
Cooling fan : 2 h
Cooling pump : 1639 h
Vaccum pump : 12.894 h
Pressure 1, 2 : 0 mbar, 0 mbar
LV : 12.1 V
Discussion Starter #15
CAP mean: 50.6 Ah
CAP min: 50.3 Ah
CAP max: 51.1 Ah
2014 EV Coupe (above)
2014 EV Cabriolet
Discussion Starter #16
A. Date of test: 1/21/2019
G. Current miles/kilometers (specify which): 16,873 miles/27,155 km
CAP mean: 49.5 Ah
CAP min: 49.2 Ah
CAP max: 50.1 Ah
2014 EV Cabriolet
Discussion Starter #17 (Edited)
A. Date of test: 1/3/2019
G. Current miles/kilometers (specify which): 9,403 miles/15,134 km
CAP mean: 51.8 Ah
CAP min: 50.8 Ah
CAP max: 52.7 Ah
2014 EV Coupe
2014 EV Cabriolet (above)
A. Date of test: 1/22/2019
B. Battery production date: 7/19/2013
C. Initial in service date: unknown
D. Typical usage: 35 to 70 mph 45 mile round trips 5 days a week with nightly L1 Charging
E. Location of car: Central California
F. At what % do you typically recharge: 35% to 45%, rarely goes below 20%
G. Current miles/kilometers (specify which): 38,625 miles/62,161 km
CAP mean: 47.5 Ah
CAP min : 50.0 Ah
CAP max : 51.0 Ah
skelly14
Hello there, a newby on the forum
I own a 453, ED 2018
I would like to know what type of interface and/or equipment you are using to read such detailed information from the internal electric circuit.
I had been involved with Hybrids and Plug-in Hybrids since 2005 until today and never seen such a report if not with a Dealer's scantool.
Thank you
skelly14
Thank you
Check out @sokoloff post here. I believe he and his son are working on a battery test unit for the 453.
https://www.smartcarofamerica.com/forums/f170/battery-test-units-available-152680/#/topics/152680
1 - 20 of 36 Posts
