would this work, if not please explain why
I believe my car still has the original coolant and I would feel a lot better knowing it was changed. If I were to put the front end up on ramps so the rear end is lower then opened the resivour cap and heater valve then removed the engine plug wouldn't the antifreeze all drain out by gravity?
Physically I cannot get up and down several times nor can I afford a shop labor rate (probably couple of hours at flat rate time)
thank you for your input
