1 - 4 of 4 Posts
is the coolant line (from rad to engine)in the tunnel a metal line or long rubber hose?
if it's a hose that could be costly to replace
thanks for the info
They are pretty well protected except for by the front of the motor, they did have some early issues with them being pinched when the motor was installed. Only heard of it happening a few times. The whole bottom of the car has a pan that protects everything
OTD3 lifetime Member
The run from front to rear are metal lines. Rubber hoses connect the metal lines to the engine and radiator.
1 - 4 of 4 Posts
