1 - 17 of 17 Posts
I'm new, just got my baby on 8/6 in Vegas. Drove back to KS through UT and CO Mts. Cruise seems persnickety, or am I using it wrong? Turn cruise on, then press set, which stays lit for half-second and goes out. Won't stay set. This problem is intermittent, so could be operator error. Any input?
Ex Admin/mod.
Your car is a 2011? If yes, does the display show that the C/C is engaged:
With the cruise control is activated and a speed set, the following message appears in the multifunction display:
2011 C:C display.jpg click to enlarge
U.S. vehicles : (1) Cruise control activated ; (2) Speed has been set
From the Owner's Manual, page 101
check the back door...
especially check the back hatch/trunk...we often have the back door just slightly ajar and the only indicator would be the interior light if you have it set to go on when a door opens. If you have it set to off all the time, you will get no indication that the back door is ajar.
The control panel on my 2011 red cabriolet says "cruise" when I turn on the cruise, and when it works right, it says "cruise set" when I set the cruise. But the last couple days, the "set" only appears momentarily, then disappears, and the cruise is obviously not set because when I lift my foot from the gas, deceleration occurs. I'll try again a few minutes later, and it will work fine. I get warnings saying "door ajar," or "tailgate ajar" when that is an issue, so, no, that would not be the problem here.
Must be a cruise control feature - our 2011 doesn't do that (or maybe I haven't left anything open....??) :)
I have had that issue on my 2011 as well. I just turn the cruise off and then back on and then I can set it. I am so used to it that I do not think about it anymore.
Nice (NOT) factory upgrade to the 2011 smart, a CC that requires resetting? :huh:
CC operation should be seamless, that has "go back to the dealer" all over it . . .
I can't blow a day of work to take it back to the dealer so they can tell me that they do not know what is causing it or they can not recreate it. I compare it to the occassional beeping after you turn off car and take out key. It happens so infrequently that it is not a big deal to me. Now if it does it all the time, it would be going back. Maybe I will mention it at it's 10,000 mile service. Should be coming up soon and I just got the car in May. Over 6,000 miles at this point. Still loving it.
Discussion Starter #13
I figured out to reset the cruise by the "old off-on trick." Must be a Microsoft product.... :). Think I'll call my nearest dealer to check out a real fix. I really love my smart fortwo....no, I mean REALLY! I still have stars in my eyes...
I am so glad I looked at this post - I've had my 451 since they first came out, and yesterday I couldn't get it to come on. I even sent an email to Steven! And then I read this post. And went to check my passenger side door. I'm really embarrassed (particularly since I've done this once before). :eek: - sheureka
:rofl2: we've all been there !!!
1 - 17 of 17 Posts
