1 - 4 of 4 Posts
my dashboard lights are dimming. Started to notice it first at the air conditioning panel and radio, now my odometer area is dimming and the radio and air lights are more dim.
I have a 2008 Passion. Is there a way to turn up the lights?
:shrug:
Etbitty
I am pretty sure the only lights you can change the brightness on is the background color on the speed o and the orange light under it. To change that just tap the right black button several times and you sill see the lights going up and then back down with every push. Hope that helps.
From the manual:
Adjusting instrument cluster
illumination
You can adjust the illumination of the
switches, the dials in the instrument
cluster, the radio*, the climate control*
panel and the auxiliary instruments*. Five
settings are possible.
  • Make sure the key is in starter switch position 1.
  • Switch on the parking lamps.
  • To brighten or dim illumination: Press right button repeatedly until the desired setting is reached.The current setting is stored.
~toaster
Bashboard lights
Toaster you are the bomb! Thank you, your instructions were right on.
Etbitty
1 - 4 of 4 Posts
