Our '08 451 continues to sit with some kind of transmission issue. If I buy a used transmission and install it, will I need a STAR diagnostics unit to reinitialize the transmission?
From what I have seen few transmission failures are due to the actual transmission; it could be you have the unusual example with a failure in the transmission, but it's far more likely going to be one of the electronic components. What diagnostic codes are you getting? Have you checked the shift motors, clutch actuator, TCU, and related harness?some kind of transmission issue
