1 - 3 of 3 Posts
Hi all. I tow our ED on a trailer behind our motorhome. I am concerned about visibility of the trailer because of where the lights are. I was considering adding additional lights to the trailer and then though about simply leaving the park lights on. Of course this will wear down the 12 volt battery. However I know the leaf traction battery feeds the 12 volt. Is this is the same thing for the ED?. Possibly dependent on key position?
Thanks again.
Yes and yes. key needs to be at least in position 1 for the DC-DC converter to be active.
Thank you. This seems like a viable solution as the lights are higher up and more visible. I would probably only do this in lower light or fog conditions.
1 - 3 of 3 Posts
