My drivers door started to rattle last week. It sounds like a mettle to mettle when going over bumps. Is there any thing inside the door that could have loosened up.? The window and locks work as they should. and the hindge is tight and in good shape:shrug:
The driver's door on my 08 Passion does the same thing. I have learned to ignore it. Others have tried moving the sticker toward the center of the car, but the rattle was still there.
Update.. it turns out the rattle is coming from the soft top rail. The alignment pin has a rubber grommet that looks to be worn out . have a temp fix for it but need to find some replacement grommets
