1 - 12 of 12 Posts
So my check engine light came on in my 2008 Passion. Turns out both O2 sensors were bad. The dealer quoted a fortune, so after a little reading I ordered 2 OEM replacements and took them to my local mechanic. One fit perfectly, but apparently the downstream sensor is a 6 wire model, so he couldn't replace it.
Problem is, I can't find that part anywhere. Evilution says both are the same, but I guess they're not. If anyone has the correct information, or a similar story, I'd appreciate any help I can get
FYI...
The wideband O2 sensor(upstream) is a 5 wire even though it has a 6 pin connector.
The downstream O2 (located in the cat) has 4 wires and a 4pin connector...
Both of them can be found on the net...
Downstream 4-wire is a Bosch 16749.
The upstream 5-wire is apparently unique to the USDM cars and I never did find a non-OEM equivalent to it. I suppose you could get a universal wideband and splice it onto the OEM plug and hope it works.
The upstream air-fuel sensor appears to be a dealer only item. I recommend you do not try to splice in a universal sensor in its place. You will be wasting your money because you will almost certainly end up buying the original one anyway when you discover the one-size-fits-none one does not work correctly.
Some cars with a wideband primary use the secondary for fine tuning on the AFR. Not sure if that includes the USDM smarts.
O2 sensors are considered a wear item, so the emissions warranty doesn't cover them.
All but completely certain that doesn't include the USDM smart, because the USDM smart fails horribly at maintaining a set AFR... and shouldn't O2 sensors be able to last 8 years? I know of at least one car twice as old and with 3x as many miles that the original O2 sensors were still doing fine on...
1 - 12 of 12 Posts
