The Smart car is the worse car in the world to drive over @#$%^& brick streets with. I have noticed my driver door seems to have movement like the latch on the body needs to be adjusted inwards a hair. I tried and it can't be done because on the latch plate there are 2 pins that align it in place. And another thing the window flutters at high speeds (door needs to be tighter to the body).
anyone have any ideas
I thought 195 tires would make a better ride, especially on brick streets......not happening
my car only has 45k on it and I swear every bushing on the front end and rear is loose/sloppy/worn out because you can hear the slop like loose strut/shock mounts
