1 - 1 of 1 Posts
if anyone is interested in installing an led driving light strip into the fog light cut-outs i have a template for the 451s that took me several hours to design and i would be willing to share with you.
this is what the light looks like. https://www.ebay.com/itm/Waterproof...ash=item33cb02d707:g:9GQAAOSw2gxY07Fv&vxp=mtr.
send me your fax number (in a PM)and i will send it to you since i don't think i could put the actual size in this message.
simply print it then cut it out and set it into the back of the fog light cut-out (can be easily pried out from the front with a screw driver) and scribe the hole to be cut out. i used a Dremmel tool to cut the hole. the same template can be used for both sides (just turn it over)
1 - 1 of 1 Posts
