As a correction, it is the ED's charger that is throttling down, not the EVSE. The EVSE is merely an electric outlet (or in your case, extension cord) with safety features, including communicating to the car's charger the maximum current that can be safely drawn from it. This is a redundancy in the case of Smart since it's charger only draws 15 amps at most - less than any 240 volt circuit it would be plugged into.It runs at 16 amps and can be throttled down to 12 or 8 amps through the ED's on board charger.
Ditto....I use this one with my Volt. I have one mounted in the garage which is plugged in 24/7 and I carry another with adapter in the car. I just leave the one the car came with in it's spot !! I too have used an extension cord and placed the unit on top of the front tire in the wheel well to protect it from rain.I have one of these and use it all the time. I took the the factory supplied one out of the car and carry the Duosida only. It can plug into 240 V or 120V outlets (with an adapter). I also made a couple of adapters to fit various oven, dryer, or high amperage outlets i might encounter when visiting friends/family. It runs at 16 amps and can be throttled down to 12 or 8 amps through the ED's on board charger. I even use a 12 Ga extension cord (100 ft) converted to 240 V (cut off ends and put on appropriate connectors) on a regular basis when I drive it to work. It is not watertight as the factory charger is, so i tuck it under or inside car when it rains. I have been extremely happy with it the last six months.
The Smart ED internal circuitry is limited to 16 amps in the US on the 451 EDs. Money spent on more amps in an external charger are wasted here unless you intend on buying something else in the near future or purchase one of the newer models.It's 240v, and portable, but it's also a WEAK level 2 charger. If it were my decision, I'd spend more and buy a charger that AT LEAST pushes 30amps (40 or more is preferred, for future proofing). Only reason for a 16amp level 2 is if you have infrastructure restrictions. Otherwise, I recommend you seek more power.
Have you checked out the new model? Your statement does not apply to the newest smart electric models.The Smart ED internal circuitry is limited to 16 amps in the US. Money spent on more amps in an external charger are wasted here unless you intend on buying something else in the near future.
You’re right, fixed!Have you checked out the new model? Your statement does not apply to the newest smart electric models.The Smart ED internal circuitry is limited to 16 amps in the US. Money spent on more amps in an external charger are wasted here unless you intend on buying something else in the near future.
This is due to a minor design or assembly flaw in many 451 ED's. What happens is the rubber weather seal boot around the car's charger receptacle grips the charger plug latch hook and prevents it from dropping into the latch - even if the plug is pushed in all the way. When this happens, the plug's button will not be all the way up and the car will not charge (one of several safety measures in the SAE car charging standard).Mine was a little wonky for a day or two but now I make sure to plug it in all the way and fully seat it in the bottom of the jack. Haven’t had a problem since. Maybe there’s some dirt in the plug or the jack? Get a can of electronics cleaner and spray both out.
I had a similar problem with our AddEnergie EVSE in the garage. The vendor provided the same advice, which worked for a few days. They then replaced the silicone gasket in the EVSE plug. Same thing. Eventually they said "its in the garage, why don't you remove the gasket". No problems since.The fix is to put some silicone spray, or a bit of plumbers silicone grease, on that boot and on the hook. And always make sure the plug button is all the way up and the car is charging before walking away!
