1 - 3 of 3 Posts
I just installed an Eaton Level 2 charging station and wanted to post my thoughts on the unit. I chose the Eaton as it was available through Home Depot Canada and was the only one that HD sold here that was for indoor / outdoor installations.
The good:
  • Stainless steel housing
  • Reasonable mounting bracket
  • 24' charging cable
  • Sturdy
  • Eaton trusted name in power systems
  • Good cable magament / storage
The not so good:
  • "Intuitive" controls, not so intuitive
  • No charging complete indicator
  • No stop button (relies on charging cord release button)
  • LED illumination an option, but not via Home Depot
I wanted to purchase a unit and have it installed by an electrician of my choice, as I found the whole process of contacting a consultant to do a review of my electrical system quite unnecessary and rather expensive. After all there is no magic to a Level 2 EVSE. It is simply a sophisticated GFCI along with a controlled relay that switches off and on the 240 V supply. The on-board controller does communicate with the vehicle and does monitor for over-current situations in order to protect the vehicle, the electrical system and ultimately the end-user. That being said, they should cost more in the vicinity of $500 and the installation is no more complicated that installing a hot tub, so a good electrician can complete the work.
All in all the Eaton is a good choice, is well made and I expect that it will be very reliable. The price on Canada is just under $1,000, which comparatively, is in about the mid range in terms of current pricing for Level 2 EVSE units.
Glad to hear its working good for you. In Ontario they have an incentive program that pays 50% of the cost of the station and installation up to a maximum of $1000. They problem I found was that the net cost in the end was far more expensive than just assembling and installing the station myself. Electricians around here are charging $75 to $100 and hour and up until recently the cheapest L2 station in Canada was $700.
In the end I got my 7.2kw L2 station installed for a grand total of $400 - next one will be cheaper.
BC has a program that covers $500 to install a home Level 2 EVSE. That pays for half of the unit itself. I am out of pocket for the electrical work, but that was less than $500 for materials and labour.
1 - 3 of 3 Posts
