1 - 12 of 12 Posts
I'm staying at someone's house all week and I've tried 4 different plugs in their garage and house and none charge, the red light blinks on the charger. I can't figure out what's going on and can find absolutely no info online. Does anyone know why this would happen? I'm going to be in a pickle with no charging all week!
I have no idea, they're on vacation so I can't ask them and they may not even know. I'm a woman so this is all very foreign to me, I'm not sure what reverse wiring means. Why would outlets not have a 'correct voltage'? The red light just means that its not charging.
Yes they all work fine otherwise..its just my car. I wonder if it's pulling too much current for it to handle...but I'm not sure why that would be. I just assumed every outlet is the same everywhere...guess not?
No problem, reverse wiring is the two spade connections in the outlet are reversed. Some electronics are sensitive to that. I have also seen where overloaded or bad wiring connections will only have around 90 volts and not 120. You can pick up a 5 dollar outlet tester at any home center. They have three lights to show proper outlet wiring. You want to see two lights. They have a chart on them to explain the use and proper/faulted indications.
Receptacle tester - Wikipedia, the free encyclopedia
Now this is a Good idea, to key a Receptacle Testing in the glove.... but it's sad when Smart ForTwo ED drivers have to be the Electricians of the world... going around testing every socket for the correct wiring...
1 - 12 of 12 Posts
