1 - 3 of 3 Posts
At our last service MB fixed some leaks in the coolant pump. As a part of this the service notes stated that they shampooed / cleaned the "engine". Which resulted in the pump being somewhat cleaner but the rest of the motor bay still as dusty and dirty as you might expect for 3 years of regular use.
Has anyone cleaned the ED's motor compartment? And if so, how/with what?
I figured I could shop-vac it and maybe (cautiously) use a foam cleaner. Looking for experienced advice ...
Thx
All the electrical connections and modules are sealed against water, so just spray on some household cleaner on the dirt spots and hose off with a spray of water from a hose. Avoid using hard stream if possible. Of course, the keyswitch should be turned off while doing this just to be double safe.
Each spring, I do it to remove an accumulation of dust and fine road salt from motor and components.
This is what I do as well, Spray everything down with simple green, let it sit for a few minutes, then a gentle rinse-off.
1 - 3 of 3 Posts
