has anyone heard of a repair shop, dealership or non-dealership, offering some kinda service to clean the rings, valve guide seals, et al.? he indicated BMW and MB shops offer this.
from what my local shop owner described it's a cleanser fluid of some kind put in the crankcase after draining the oil. the engine is run for a length of time then drained. new oil is put in with some other additive.
what brought me to this is oil needing to be topped up/added every 3k miles or so. and he's also checking on the PCV assembly thingy being faulty.
now, I've personally done diesel soak and run (replacing the crankcase oil with same volume of diesel and running 15-20 minutes but ONLY AT IDLE, not under load of any kind and no revving) on many older engines simply b/c I couldn't determine what kind(s) of oil had been used by the previous owner(s). and I've had very good luck with this. the clear-ish diesel comes out black & gunky.
anyone have thoughts on if this possibly being about the same thing only he wants to charge $150...
thanks in advance!
thanks in advance!
