Head light warning light comes on and there is no drive it happens when I wash the car are use the washers switch the engine off and on and wait till the light goes out then the drive ok
2017 453 ForTwo Coupe ED
It sure sounds like wire insulation is worn and water is causing a short. Someplace around the front windshield. Wiring go through a hole someplace where the insulation could rub? That is the first thing I would look for. Of course, I could be entirely wrong.
Certainly sounds like a short somewhere. Which year/model?
2005 passion
It sure sounds like wire insulation is warn and water is causing a short. Someplace around the front windshield. Wiring go through a hole someplace where the insulation could rub? That is the first thing I would look for. Of course, I could be entirely wrong.
thanks
