My check engine light came on yesterday when I left work. I am not sure I cranked down the gas cap on the last fill up; could that be it? I refilled it this morning but light has not gone off.
Mine came on last night as well. I filled up yesterday morning on the way to work, after work I was on the way home when it started running on 2 cylinders, the engine light came on. I was in the middle of nowhere, so I kept on till I got home. I have a scan gauge, NO CODES FOUND. It was a little scary getting up inclines, I managed to get up my driveway, checked scan gauge again, still nothing, it started smoothing out. I shut it off, restarted, it was running normal, engine light off. I'll see what happens when I head to town this afternoon. I'm right at 15000 miles. I did check gas cap it was tight
Did you talk to Joe at SCI ??? :wink:Mine came on last night as well. I filled up yesterday morning on the way to work, after work I was on the way home when it started running on 2 cylinders, the engine light came on. I was in the middle of nowhere, so I kept on till I got home. I have a scan gauge, NO CODES FOUND. It was a little scary getting up inclines, I managed to get up my driveway, checked scan gauge again, still nothing, it started smoothing out. I shut it off, restarted, it was running normal, engine light off. I'll see what happens when I head to town this afternoon. I'm right at 15000 miles. I did check gas cap it was tight.
