1 - 20 of 26 Posts
Hi there. I purchased used 2008 smart and i noticed that the engine has a lot of vibrations at idle when it warms up. When the door is open you can see it vibrating. The side mirror vibrates at red lights. I have changed lower motor mount but that didn't change anything. Thinking it could be side mounts or spark plugs? Any thoughts?
Discussion Starter · #2 ·
...wow...that doesn't look good or sound good...
...for sure check engine mounts while under a load...lower mount keeps engine from pitching up-down...hard to see in video which way it's moving...side to side or up-down
...I'm more concerned about the metallic sound....no CEL?
Jetfuel...
Jetfuel...
There was no codes until i started unpluging coils. Now i have a CEL. Car runs good except vibrations.
Some suggestions...
Change the spark plugs, ohm out the coil packs.
Rum half a bottle of Techron, the black bottle, through the gas tank.
Check fluid level in transmission.
All else faila, do a compression test...
I replaced all 3 engine mounts last week - you can buy all three for 99 usd or order them separate all 3 for 89 usd which i did..
See here:
What did you do with your smart today?
No big deal, you need a car jack E12 and E18 star sockets and a ratchet with M16...
Zero vibrations anymore. My old engine mounts where totally wrecked after 151xxx miles!
This is great! I'll probably do this pretty soon! Didn't realize it was so simple (and relatively inexpensive). And my car only has 54,000 miles but still has all of these symptoms. The last owner must have driven my car very hard.
Discussion Starter · #16 ·
I am getting the mounts today. Hopefully this will fix the vibrations. How can i tell if the mounts are shot? The rubber looks intact, but because of limited access cant really tell if its actually broken.
1 - 20 of 26 Posts
