Gots to post this for increased notice -- I have an EOnon radio (DVD/GPS/TV etc.) going into my 2012 Smart.
I have the Metra 99-8720b fascia plate, as well as plug and antenna plug.
While the Smart Power and Speaker plugs all actually match up correctly with the Smart plugs, the wiring is a little off.
Previous post by a forum member regarding the wiring schematic of the plugs of a 2012 Smart are not exactly what is in mine -- and the wires from the Eonon do not equate with the Smart wires.
For instance, the Eonon has wires for: 1) gps 2) bACK UP CAMERA 3) mUTE 4) mEMORY 5) POWER ANTENNA 6) empty 7) Ignition Key 8) Ground;
Whereas the Smart wires are for: 1) Unknown 2) empty 3) empty 4) Constant 12v+bATTERY 5) amp power 6) Dimmer 7) 12V+Ignition 8) Ground
I tried it all regardless of wiring, and the radio would turn on, the face lit up and showed stations, but no sound, and within 20 seconds, the unit turned itself off.
I removed the mute line, the back up camera, the power antenna -- no change.
What do I need to do to get sound?
Why is the unit turning off within 20 seconds -- tried it repeatedly.
Thanks for any help.
