The Ultimate EDpassion 150
Tuning to the max:
• 150 HP
• 270 Nm / 1.200 Nm (motor / wheel)
• maximum driving enjoyment
For 999 €*
Together with the community I'm currently developing a 150 hp tuning for the electric smart ED (BR 451). This will work for every model from 2012 to 2016 and would make your smart even more fun to drive.
In the meantime I have gone through the entire drivetrain of the smart ED and I'm convinced that up to 150 hp are possible. Of course, this does not improve its longevity, but that is also not the point of tuning. The HV contactors can handle the peak performance without any problems, the battery cells have been validated with 300A in at Accumotiv and the motor can already produce 110 HP ex works. Accordingly, it should still have room for improvement. The mechanics will be the weakest component. We have to try out what gears and drive shafts do with the massively increased torque and, if necessary, install reinforced parts.
The topic is still in the development phase, but has now come to a point where I would like to share it with you and discuss it here.
What has to be increased is the fuse in the battery. It's just a 225A fuse and thus allows only up to 100 PS, accordingly it is also clear that more than that is not easily feasible. Thankfully a 300A or 400A fuse can be installed easily.
The main sticking point is currently that the inverter has a software limit of 200A. You can fool it however you want, that's it's limit. That's why I've given an inverter to a local tuner. Since the inverter is from Continental, he is optimistic that it will get cracked. Continental combustion control units are no problem for him.
Interested?
Contact me via [email protected]
... also if you want to participate in the development.
You would rather be interested in an inexpensive tuning or just increase the range a bit?
Have a look at my blog, where you can find out everything about the 100 hp and regen tuning:
Tuning the smart ED3 to 100 HP or simply make it regenerate more?
* The tuning is still being developed, the price can vary.
Tuning to the max:
• 150 HP
For 999 €*
Interested?
