Hi, A month ago my 12v battery died on the car and nothing would work. Didn't know there was a 12v battery in the car, lol... figured it's electric it must be just 1 big battery. Changed the battery, car came back to life and working great with more miles than before for some reason. But today noticed that the portable charged is like "melted/melting". I had noticed the small discoloration a while back but that is all it was a discoloration but today say this (see pictures)
The car charged just fine to 100%. No idea if it was like this before I charged the car since the way the car is plugg this "more severe" damage is behind and I can't see it when I plug it. There was NO BURNT smell in the garage when I went to the car today. I have a feeling this happened when the 12v was bad and the car was not charging but because the "small discoloration on one of the pictures" was seen months ago maybe this cable has been going bad for a while??
I have a 2014 smart for 2 electric, the one on my profile picture
QUESTIONS
1- Can I still use it? If I still use it what is the worst that can happen?
2- Where do I get a replacement?
3- How much?
This is the only car I have to get around so I need a quick solution.
I looked on Amazon for charger but they say things like LEVEL 1, LEVEL 2... no idea what I need of what is a good charger. At home I plug the car in a regular 110v outlet. The charger is OFF the floor attached to the wall. It's a clean dry garage with no obstruction that can cause water or heat to get to it. When the car is done charging I unplug the car end and the wall end until it's needed again.
Thanks in advance for any input!
QUESTIONS
3- How much?
