I have a 2008 451 with the nine spoke is it the same one you need ...
Fannum... I just got one from a guy in Ft. Wayne Ind.and I think he had two fronts so he may still have the other , I'll check with him and if he does I'll have him contact you hows that .rawv here’s the wheels mine has on it(this is the warped wheel that needs replaced)
fannum I wish I was closer to you but I’m in Tennessee or I would take you up on it.
I just need one unless I can get a good deal on a set.
Thanks.
It's a common oversight by tire guys that should know better. The NTB place I use has overlooked it more than once. Last time they did, and I had them redo the tire, it went from 2 ounces to 1/4 ounce of balance weight. Huge difference.Shalmaneser64 I never noticed that the dot is in the wrong spot.
The car is currently in the shop for head gasket replacement so I’ll have them take care of it.
You might consider finding a set of rears so you have same size tire all around. Many do. I also carry a front steel rim with a 125/18 15 donut spare in my three smarts, behind the passenger seat.I’ll still need a wheel or two for spares though.
The standard rear size tire fits fine up front. If you start to go wider and or taller, then you need to be careful. But even then, there are solutions. Lift kits, taller springs.Ok
I tried one of my rears on the front but was concerned about clearance with the panels.
I may give it a try as I would love to be able to do tire rotations like I do on my other cars.
That and the price for them isn’t that big of a difference.
