1 - 2 of 2 Posts
is that Evans waterless coolant better than the factory stuff? sounds expensive to run the cleanout stuff thru first than the coolant itself.
instead of doing the manual draining how does the power flush work?
From what I have heard, the waterless coolant is much better as it doesn't have any air mixed in with it. It is only expensive the first time you put it in and it needs to have all the water/coolant removed to work right. So far the stock stuff has been working for me, but if I lived in a hotter climate. I would give it a try.
1 - 2 of 2 Posts
