Quote
Set/Minus switch (long): Rotate down and hold this switch for approximately 20 seconds until the LED shines red and then let go. Note that after 10 seconds it will flash green as mentioned above - KEEP holding it until it shines red to enter this mode! This mode is used to set/change the TheftProtection code.With the LED shining red Enter the current 4-button code sequence (the factory setting is PLUS, PLUS, PLUS, PLUS or MINUS, MINUS, MINUS, MINUS depending on the software version). Once correctly entered, it moves to the next step.With the LED now shining yellow Enter your new 4-button code sequence. It can be any 4-button sequence using the Plus, Minus, and Mode buttons. Once entered, it moves to the next step.With the LED now shining green Re-Enter your new 4-button code sequence.If everything was entered correctly, the programming mode will automatically exit. Otherwise, you will start over at the beginning of this programming mode.While Stopped:TheftProtection: With the key is in the ignition (or even a few seconds after the key has been removed), you can enter your 4-button sequence (see Setup section above) to engage or disengage the TheftProtection feature. The LED will shine red when the TheftProtection is engaged and will remain that way until it is disengaged with the proper code. After entering an incorrect code, 5 seconds must pass before another sequence is tried. Be CERTAIN you remember your code! There are 81 different combinations to try
