Just wondering if anyone has replaced the stock subwoofer speakers under the seat?
What brand / size woofer did you use?
Do I understand this correctly? You have or want a trailer behind your smart with a generator and subwoofer for your bass? I am getting old.B-52 Professional: Precision For Your Passion
Mounts on the trailer behind the open tailgate. Audio drop from the old woofer to the input of the 1.2 KW bass amp is pins 5 and 6 of the trailer light plug. Power is from a Honda EU3000i mounted behind the speaker in a Hayes custom cooled enclosure with Hayes keyless push button start marked BASS BOOST:
honda eu3000is generator 3000 watt super quiet electric start inverter equipped Honda generators
The 12A charger output recharges the Smart battery on BASS BOOST via pins 7 and 8 connections in the trailer plug. You can run it at the beach for 12 hours without refueling, wide open...if nobody calls the cops.
Mine IS bigger than YOURS.
Even the pimps in the Escalades can hear it....4 traffic lights up!
I know this is an old post, but if I can manage to get back to town, you'd be welcome to come out to the shop and build something. I am the Wood-master (I'll show you the walnut-wrapped inlaid burl satellite/subwoofer combo I did (for the house -- wouldn't fit in the smart). rigging up something won't be too hard.I wouldn't spend any time on the under the seat sub - it's not worth it. Our door speakers are bigger than the "sub" driver in that enclosure. Instead, the under-the-dash option is the way to go and will put out a LOT more sound than something that fits under a seat. Personally, $300 for a box and driver is WAY too high, I'll be making my own box one of these days. The amp will then go under the passenger seat.
I think Larry was being a little tongue-in-cheek on that one. But do notice the steep filter at 30 HZ -- these are made for bands, not high-fidelity sound reproduction.Do I understand this correctly? You have or want a trailer behind your smart with a generator and subwoofer for your bass? I am getting old.
I put a Boss powered sub woofer under the passenger seat. Works and fits great. Got it on Ebay slightly used for $75. Of course I am old, so I don't need it to rattle the dashboard of the car next to me at the light.I wouldn't spend any time on the under the seat sub - it's not worth it. Our door speakers are bigger than the "sub" driver in that enclosure. Instead, the under-the-dash option is the way to go and will put out a LOT more sound than something that fits under a seat. Personally, $300 for a box and driver is WAY too high, I'll be making my own box one of these days. The amp will then go under the passenger seat.
