Status
Not open for further replies.
1 - 3 of 3 Posts
Admin emeritus
A vast collection of (almost) all technical infos (start at post #1)
SCoA MEMBERS ONLY
http://www.smartcarofamerica.com/forums/f35/club-technical-library-36527/
Car won't start after disconnected battery: re-teach the car
http://www.smartcarofamerica.com/forums/f25/disconnected-battery-wont-start-11676/
Engine swap
http://www.smartcarofamerica.com/forums/f35/club-technical-library-36527/#post406736
Certain fuses are missing in the NA 451 Owners Manual (pg 285). List at:
http://www.smartcarofamerica.com/forums/f25/missing-fuse-page-redux-19408/
DIY Gear Shifter and Lube (Video @ post #48)
http://www.smartcarofamerica.com/forums/f25/diy-gear-shift-removal-lube-short-video-5428/
How to adjust your headlights, very easy!!!
http://www.smartcarofamerica.com/forums/f25/headlight-adjustment-easy-4088/
How to install a switch to defeat the "on all the time" heated mirrors
http://www.smartcarofamerica.com/forums/f25/heated-mirror-switch-diy-14102/
Replace/repair the cabin air heater/AC electric fan
http://www.smartcarofamerica.com/forums/f25/heater-blower-motor-repair-26967/
How to Jack Up Your Smart Properly
http://www.smartcarofamerica.com/forums/f25/jacking-points-13110/
Disassembling, changing the key battery:
http://www.smartcarofamerica.com/forums/f25/key-went-through-washing-machine-39059/#post439160
Locked out and the car batter'y dead, someone's experience and tips on how to open the door
http://www.smartcarofamerica.com/forums/f25/key-does-not-fit-manual-hole-36145/
Reset Maintenance Interval
http://www.smartcarofamerica.com/forums/f25/reset-maintenance-interval-11415/#post404393
or
or http://www.smartcarofamerica.com/forums/f25/maintenance-indicator-reset-service-wrench-17189/#post433688
Online Technical Manual (by subscription, cheaper than smart's)
http://www.smartcarofamerica.com/forums/f25/repair-information-online-repair-manual-37475/
Gas Miles per Gallon tracking
http://www.smartcarofamerica.com/forums/f25/gas-miles-per-gallon-tracking-2628/
How to change your oil in the smart
http://www.smartcarofamerica.com/forums/f25/semi-official-how-change-your-oil-3480/
List of oil/filter
http://www.smartcarofamerica.com/forums/158860-post4.html
Parts, good source for used parts, including full engines
http://www.smartcarofamerica.com/forums/f48/blown-engine-please-help-34439/#post380623
Rear Window Washer's not getting fluid? Check the connection (pic)
http://www.smartcarofamerica.com/forums/f4/rear-window-washer-20525/#post208539
Shifter Stuck in Park, here is the get home now fix
http://www.smartcarofamerica.com/forums/f25/shifter-stuck-park-heres-get-me-home-fix-5578/
Maximize shifting for optimum MPG/torque...
http://www.smartusa.com/Downloads/How-to-Maximize-Fuel-Economy.pdf
Fabric Sunshade Installation
http://www.smartcarofamerica.com/forums/f25/fabric-sunshade-installation-4626/
My Car Won't Start and the display reads three bars instead of P
http://www.smartcarofamerica.com/forums/f25/my-car-wont-start-3-lines-thru-p-6105/
When all else fails, check our in-house Supporting Tuner.
Evilution - Smart Car Encyclopaedia
1 - 3 of 3 Posts
Status
