I think I have read all the posts on this subject here. But they all seem to be at least 5 years old or more.
I have a 2013 that I'm just starting to tow. If I go through the tow procedure exactly from the manual, after connecting the battery again it goes through a transmission relearn or something (sounds like a bunch of clicking). Sometimes I even get a check engine light. If I don't disconnect the battery, everything is fine.
I read an old post (2012) from "Libero" and he says, "It seems to me that the reason for the battery disconnect is to ensure the key does not inadvertently get into the "run" mode (position 1) while towing or the transmission does not move from neutral." He made a lock plate that ensures the key won't turn and it won't go into "D". I kind of think that makes sense. So, I made a lock plate too, except mine is made from plastic. I removed the "fob" from the key part. See pics.
I guess I just don't like all the trans relearning and occasional check engine light after re-connecting the battery. I've done a short test tow with just the locking plate and left the battery connected and all seemed ok.
My question is, would you be comfortable using a locking device like this to lock the key and shifter? And not use a battery disconnect switch? With the lock, the key can't turn on and the shifter can't be moved to "D".
Thanks.
Thanks.
