81 - 89 of 89 Posts
2017 Passion Coupe
Now I understand your post, Mud Pie! I thought you were stating your opinion on fog lights while, instead, you were summarizing the thread.
I don't remember this thread from the first (three) time(s) through. Why I missed it, i don't know.
One thing that has changed since the earlier days: with different software, the fog lights will no longer be on when high beams are used. I had my fog circuit activated (without the fogs themselves) for other reasons and found out about this little tidbit.
This must be a recent change. I had my fog lamps activated in May, and they stay lit when the high beams are switched on.
2017 Passion Coupe
It may be the method. There were troubles getting mine activated "simply" so for the more elaborate enable I was cautioned that I'd lose the 6-lamp "feature."
That makes sense.
By the way, thank you again for the spare plastic panel clip. I really appreciate it, and please let me know if I can ever be of help. :)
2017 Passion Coupe
Karma was rewarded with a call from my Smart Center - he had a couple clips from a panel they replaced. I should put those in!
Gosh, I was thinking about buying the lights that are mounted lower (I'm afraid to call them fog or driving lights), but after this thread, I don't know if I want all that controversy in my life....YIKES! Worse part is, I read EVERY post for nine pages! I gotta get a life!
Yep, it is. Been doing experimentation with the Water into H H and O. Thus my name on the forums. If I get a good system down and working real good, I am going to hook one up on the smart car to push it past the 65 or 70 mpg. Thus a plate that says 80mpg like the one girl has, won't be a fib, but actually telling what it is. Then, if it works great, I might actually sell you all the plans so you can thus have a HYBRID Smart that gets better MPG then that stupid looking Prius.
:D
Did you get your creation to work??
81 - 89 of 89 Posts
