1 - 2 of 2 Posts
Hey everyone, went to replace one of the side light bulbs in the headlight assembly and realized that one of the wires connected to the harness has become detached. Any fix for this, can the wire be tapped back into the harness? Or can the harness be opened up somehow to put the wire back in? Thanks in advance!
64149
64150
There are a few options:
If you can source a new connector and pins, you could clip the other wire and use butt splices to connect it to the old wires
If you can solder, you could trim what little wire there is in the connector, put a piece of heat shrink on the broken wire, strip the wire back a little and solder it onto the connector, pull the heat shrink up to cover the solder joint and apply heat to seal and protect the exposed solder contact.
Does this help?
1 - 2 of 2 Posts
