I've now taken my car in 3 separate times (for a total of 8.5 hours) for this issue, and it's not being resolved at the dealership. so, i'm asking you fine people for insight.
I've had my smart since march 28th. i've put 7,300 miles on it, thus far. around april (1,200ish miles) i noticed that when i was on the interstate, that i'd get a high pitched metal on metal squeal/scrape sound coming from my front passenger wheel when i'd veer or turn to the right. it only happened on the interstate after going 80-85 for over 10 mins, once the wheels heated up. so i'd hear it while passing other cars and on the offramps.
i took it in for the squeal and this clunking noise i'd get when i'd turn sharply. my suspension bolts were tightened, which helped the clunk, but not the squeal. the dealership told me that the tech couldn't reproduce the squeal. well, of course, on my way home from the dealership it started squealing again.
so, i decided to wait a few weeks until it got worse, so maybe the tech could reproduce it. now my car will squeal while veering right OR left (and it sounds like it's coming from both wheels now), for a sustained period. only when i'm going fast, and sporatically. sometimes shaking my steering wheel seems to fix it, sometimes it doesn't. of course, it's completely random, but happens at least once a day.
i left my car at the dealership half a day and the service manager drove my car around and heard the sound, but again, the tech couldn't reproduce it. the official write up on my paperwork is "valve ping from using regular gas". which i don't believe is the case as a.) i've never used anything other than premium and b.) the noise is coming from the front of my car, away from my engine.
i've checked the calipers, there seems to be clearance between them and the rotors. my suspension is tight. the paperwork says my clutch is fine. what could it be? i've been worried that maybe it's the power steering belt or something, as the noise sounds like something between a brake squealer and a slipping belt (i've heard this same sound on other cars with a dented brake shroud that was scraping the rotor, and a bad wheel bearing), but i really don't believe that's the case.
