1 - 10 of 10 Posts
So, I had to replace my fuel pump because I got the dreaded "all bars blinking" issue. That is now resolved. However, now I'm only showing 6 of 8 bars even though the tank is full. Is there some sort of recalibration that needs to take place after replacing the fuel pump?
Thanks!
Kevin
Spoke to the dealer (not local as the local MB dealer doesn't deal with Smarts). They said the only thing that might cause it is a physical restriction of the float (doubtful) or the instrument panel hasn't reset yet. So...I'm going to drive it until the low fuel light comes on and refill. Hopefully that will reset the gauge. If not, I may be dropping the tank again. ...yea.
I had the entire tank replaced under warranty by Penske MB in Chandler on our 453, due to the errors with the gauge and capacity. On that model, the entire assembly is just that, not separate parts. We got a new fuel pump, tank, and sender unit. It still doesn't read correctly, but it is better than the original. They told me there is no calibration as such to be done. So...another Smart peccadillo.
S u b R o s a
Discussion Starter · #7 ·
S u b R o s a
Wow...that stinks. The fuel pump and pressure sensor cost me about $300. Can't imagine what the whole ass'y would cost. :(
1 - 10 of 10 Posts
