1 - 9 of 9 Posts
Does anyone have fuses listed with their function?
I have an awful lot of fuses for a car with so few options.
Want to maybe pull or toggle battery/water heater when range is low
Sent from my SM-N960U using Tapatalk
Suggestion on fuse designations: RTFM!
And I really don't think that disabling the heater if it exists and it can be done without disabling other components, is a good idea. According to some sources, the heater is only used for the ED's with the 22kw charger - i.e. only in Europe. I do know that my diagnostics still shows "0 hours" for my battery pack heater after 4 years of use in temperatures down to -15F. And, as I previously explained, the battery heater is not going to drain the pack much over the course of an average trip.
A better investment would be to use range-optimizing driving techniques and consider alternate routes - in particular, avoid high speed expressways.
Never do such a thing... a few watt hours are not worth damaging the battery.
Side note:
There are no fuses for the battery on the 12V circuit.
Proof the USA got the heaters on the electric cars liquid cooling loop
In-line Fluid Heater from Electric Smart Car, EV West - Electric Vehicle Parts, Components, EVSE Charging Stations, Electric Car Conversion Kits
I have a regular route that consumes as low as 4KW, I used almost 6kw today due to cold temps and I suspect batt water heater. Need to leave car plugged in so water stays warm, I think wattage of warmer is not so high so it cannot catch up once things are very cold.
To check if there is a battery heater, simple check if the cooling loop is warmer or colder than the battery cells.
I came across this interesting page, but I have no idea if the EV models share the same functions.
They are quite similar, I still can not understand. Thanks for the information.
1 - 9 of 9 Posts
