1 - 3 of 3 Posts
I see the fuses under the dash on the drivers side
does this drop down at all so you can actually ready or see what is
going on with the fuses besides trying to lay there upside down
You can take the ZEE unit/SAM out but that's more work than getting under the dash to see the fuses. Helps to have the fuse chart when you go looking. :)
It would help to know what year your car is, don't you think?
If it is a model 451, model year 2008 to 2015, then the SAM or fuse panel has a latch at the forward (firewall) end that can be released to swing the panel down.
1 - 3 of 3 Posts
