1 - 20 of 31 Posts
So my beloved 08 fortwo got its first flat yesterday coming off the Williamsburg bridge into Manhattan. The valve stem came loose somehow so a refill was not an option.
My question is, can I buy a spare wheel that would fit front or back just to limp me home or even a donut type wheel.
Also, would putting 2 rear wheels on the front make this whole process easier and what is the difference between front and back wheels? Is it only the width?
I know a lot of neophyte questions but I just started a new job and really need my smarty on its feet. (!!!)
I'm running 15X6 wheels all around, and actually have a 5th so I can rotate tires like they used to when cars had full size spares. The 5th is too big to carry on a daily basis though, so I had a Kumho T21 temporary spare - 125/80-15 95M mounted on a steel 4.5 inch front rim with a standard valve stem. It fits nicely behind either seat. Have a compact jack to go with it, so I should be good to at least get home.
Yes 64 that's what I am thinking of. How did you get the 2 other 6in wheels and how much did you pay? I found them on ebay for $75 ea.
I haven't junkyard shopped for any but cant figure there are many around since the car is rare.
To clarify, my 6 inch rims are new German made alutec alloys from Tire Rack. they are about $115 each. Very pleased with them. I couldn't find much on ebay. The Kumho temporary spare is about as narrow a tire as you're going to get to fit on a 4.5 inch steel rim. It's a donut, with the obvious speed and range limitations, but I'm not going to be more than 50 miles from home.
What do you need now? Are you in a jam and need a spare rim/tire to get you going tomorrow. Or at this point you got repaired and are just looking for a spare tire solution going forward. I can bring you a rim and tire to use to get you through if you are stuck just get it to a local tire fix shop, assuming no spare also means no jack of lug wrench. Because tires are not at all the issue, its when you are scrambling for a 3 lug rim that could get you strung out.
Also you guys with spare tires, what are you carrying for Jacks and lug wrenches?
I'll figger this car out
There are a number of scissors jacks available from various cars. My lug wrench is unique because I have left the 15mm lug nuts that were originl equipment on the car. This a 15mm socket 6" extension and 1/2" x 24" breaker bar take care of everything.
Soon, I will show people my tool kit which fits in the rear door , when it's done.
I have Chevy AVEO jacks from ebay (looks like they've never been used) for both Smarts, and extensible lug wrenches from amazon. Jacks are bolted into tires, sitting behind passenger seats, and lug wrenches sit in rear compartments.
That's what I
That's what I'm talking about. Chevy aveo Jack's. That's hot.
Discussion Starter · #12 ·
So I fixed the flat the next day, it was the valve stem/ TPS that came loose so a refill was impossible. Just bought a new stem & swapped it. I found the rims on ebay for $75 for the steel ones which match what I have, just have to get a TPS and tire.
I think long term 4 rear rims is the way to go but I will probably sell this 451 to get another one this spring so may just get a front tire now as a makeshift donut.
Discussion Starter · #13 ·
Hey huge 2nd (or more) question
On my spare, will a standard rubber tire stem fit in the wheel or do I need the TPS to make it work?
(I get it will show low tire when I do this but that's fine)
A standard stem will work for the spare. Fed regs say a car with TPMS has to have sensors on the main tires, but doesn’t apply to a spare, as I understand. Not like the Tire Police are going to be looking...
IMPORTANT: If fitting the spare or spacesaver behind the seat then tie it down with nylon rope, from seat runner through the spare to the other seat runner. This will prevent it moving in case of an accident. I have my spare behind passenger seat, and my Jack and brace in a bag behind the drivers seat. As for 453 Fortwo, do not worry that your spare does not have a TPS sensor, as you are only putting the spare on temporary and then taking it off again ASAP. The TPS sensors should only be on your four road wheels.
1 - 20 of 31 Posts
