1 - 3 of 3 Posts
I need a headlight for an experiment. I just got done replacing the projectors in my Fiat and want to do the same for the Smart but I need to know what projectors will fit in the housing.
Thank you.
Thank you for the link.
I came across GreyMatte451s posts after I put this thread up. I saw that he had issues with the Hella projectors fitting. He said the the mounting tabs on the bi-xenon projectors are way too big and don't clear the plastic bracket that surrounds the projector and holds it in the headlight housing. The mounting holes are identical between the projectors and so theoretically they will bolt right in...if there were room for the metal mounting tabs of the bi-xenon projector! The mounting tabs on the halogen projectors are much slimmer and fit rather precisely in the projector bracket.
I still want to get my hands on a headlight to experiment with. I'd like to do some testing with ZWK-R glass in the stock projector. I just got done installing E46 projectors with the ZWK-R glass and the cutoff is phenomenal.
Retrofit
E46 projectors
1 - 3 of 3 Posts
