1 - 4 of 4 Posts
I have a post on "wanted" for a headlight switch, I broke mine off! Question is... mine is the one without the auto position p/n 4515450110, will the one WITH auto p/n 4515450120 work?
Thanks!
The "auto" function obviously won't (you don't have the sensor)
BUT, I THINK the connection should be the same, so the other functions SHOULD work?
Ebay has some used ones auto function and are few dealers, but no one seems to have the other one! I can live without the auto feature working if the switch will work...
Should be fine. The stalk used by MDC has several settings not used by the default stalk on my cabrio (the rear window washer kick back, for example). But otherwise it works fine. I can't imagine the other stalk is dissimilar enough to not work.
1 - 4 of 4 Posts
